help
No tech discussion, please
elvis67
help
Post by elvis67 »
HI guys I like to know if those would fit on my 67 for a 302 swap dont know the year of the frame that they are on sombody can see by the pic hope sombody can help me please 5 pic 2 post
Re: help
Those look about right for small block stands. http://www.fordification.com/tech/engine-perches.htm Here's mine.
elvis67
Re: help
Post by elvis67 »
Y'a they look the same I read the engine perches topic and dont understand all of it the part of 77/1/2 To 79 is onclear for me and I think that the frame is maybe a 78 so Will thé fit on my 67 ??
Re: help
They'll work. Just pay attention to the hole locations. The crossmembers and frames were drilled for all variations of engines. Just make sure you use the small block holes. You can zoom in on my photo and see which ones to use.
elvis67
Re: help
Post by elvis67 »
Thanks Randy I Will check my frame and post pic to make sure Im in the Wright place
elvis67
Re: help
Post by elvis67 »
the way I see it the left side perch would go 3 4 5 7 and right 1 in the square hole 3 and 5 7 if Im not mistaken right???
daveford72
Re: help
Post by daveford72 »
When I took my 240 I-6 out and put in an 86 302 mustang engine in my 69 f100, I had 2 drill 1 hole on each side. The front cross bar is different from 67-69 vs 70-72 The 67-72 is stronger (has inside channel) 70-72 does not on 2wds.
