Where to purchase door seal
No tech discussion, please
TexasVine
Post by TexasVine »
Looking to get a new door seal for my 67. Any suggestion where I can buy one with the original dimensions and fit?
Thanks,
Mike
1967 Ford 100/352/4 speed/PB/LWB
2014 Ford F150 KingRanch 4x4
jzjames
Re: Where to purchase door seal
Post by jzjames »
I used these and they fit very well.
http://www.ebay.com/itm/NEW-Front-Door- ... 8a&vxp=mtr
ThinLizzy13
Post by ThinLizzy13 »
I can tell you where not to order from...
I've ordered from LMC for a 63. They didn't fit right. Been on over 1.5 years and the doors still don't shut right. I've seen people on the forum talk about the same issues for the bumps.
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
Busboy
Post by Busboy »
I got all mine from D.C. They were of good quality however the installation needs to be done carefully.
1967 F-100 4x4 custom cab.
Subzero
Post by Subzero »
Like ThinLizzy13 said I've heard issues with LMC ones. Soft Seal makes good ones too
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
Wilfred of Ivanhoe
Post by Wilfred of Ivanhoe »
I have used the ones from LMC with no issues. I did use Gorilla glue though.
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
My427stang
Post by My427stang »
The only good ones nowadays are from Soffseal. They match original dimensions and are as inexpensive as any. I have done a few now, replacing the "doorslammer" repops
You won't be disappointed
