1995 FORD F450 SD V8 7.5 DUMP TRUCK
No tech discussion, please
Papa M
Postby Papa M » Tue Jul 20, 2010 1:39 pm
Just purchased the truck, seems like the Hydralics may be bad, or I just don't know how to operate. I activate the PTO by pulling a handle on drivers side, then I move a handle installed on the vehicle hump. I can hear something going on but the dump bed does not lift.
Anyone out there that can help, sure would appreciate. From labels adhered to the Dump bed, the dumper package was installed by Crysteel. Looks like the dumper works on a transmission driven hydralic pump.
Thanks,
Papa M
Re: 1995 FORD F450 SD V8 7.5 DUMP TRUCK
Postby fordman » Tue Jul 20, 2010 2:23 pm
this post is in the wrong place. here is what i would check. in this order. hydralic fluid level. pto cables and thier operation. do they actualy move the lever on the pto. the pump for the fluid. and verify the flow. if you are gettign pressure to the cylinder then the cylinder is not working for some reason. if you arent getting pressure to the ram then it is a problem above. ie bad pump or stuck relief check ball. if it is getting pressure then it is possibly a check ball in the ram.
Papa M
Postby Papa M » Tue Jul 20, 2010 4:57 pm
fordman wrote:this post is in the wrong place. here is what i would check. in this order. hydralic fluid level. pto cables and thier operation. do they actualy move the lever on the pto. the pump for the fluid. and verify the flow. if you are gettign pressure to the cylinder then the cylinder is not working for some reason. if you arent getting pressure to the ram then it is a problem above. ie bad pump or stuck relief check ball. if it is getting pressure then it is possibly a check ball in the ram.
Thanks, the pto cable does move the lever, where is the relief check ball. Someone told me that the hydralic fluid tank is under the dump bed, how can I check for fluid if I can't get the dump lift working. Also, where in the forum should I be posting?
Postby fordman » Tue Jul 20, 2010 5:37 pm
all the check balls woul dbe internal in the pump and or cylinder if it has one. the tanks i have seen have sight glasses in the side of them. but those are on larger trucks. the fill may be on the pump. i really do not know the system you have i was only giving guesses as to what i would look at. if the tank is in the frame under the bed. you will have to crawl under the truck to find it. it may fill there for all i know. i have no idea where to fill it at.
67bartcat
Postby 67bartcat » Wed Jul 21, 2010 9:42 pm
is it a auto or a manual trans. we have a F450 auto bucket truck at work and it has to have the e-brake on to work
Postby Ranchero50 » Fri Jul 23, 2010 10:46 am
Clutch has got to be out ofr it to work as well... Usually you can look under the bed between the frame rails and see the tank and can usually fill them with a kerosene heater transfer pump (squeeze bulb setup) or a squeeze bulb fuel line from an outboard boat motor setup. Personally I would be looking for leaks etc and maybe calling the folks you got it from first.
Seems they should have demonstrated it before you bought it???
Jamie
Builder of dreams, breaker of hearts. Play nice or go away.
70shortwide
Postby 70shortwide » Sat Jul 24, 2010 9:21 am
4wd? try putting the transfer case in neutral and the trans in 4th. thats how the pto worked on our old pump truck
Jeff W.
Pussies will never be heroes
Beware of cars with primer for paint, the money went under the hood
1970 F100 SWB CV Front, Big block, C6, 3.50 gears
1993 Chev Suburban
1969 F100 LWB lifted 4" 390 4 spd 3.50 gears, 32/11.50s
2004 Honda CBR 1000rr
averagef250
Postby averagef250 » Sat Jul 24, 2010 3:17 pm
If the pto's on the tranny it runs off the counter and operates in any gear and nuetral provided the clutch is out. If the pto's on the t-case the tranny must be in gear, any gear (reverse is probably a bad idea).
Return to “General Discussion”
Who is online
