What did you do to YOUR bump today?
No tech discussion, please
Jacksdad
Re: What did you do to YOUR bump today?
Postby Jacksdad » Tue Mar 21, 2017 1:27 pm
Thanks Kyle - we're getting there slowly but surely. I have someone that contacted me about the seats a while back, but I'm not sure if he's still active. I just PM'd him to see if he's still interested. The passenger seat is in great shape, but the driver's seat has small cracks in the vinyl from use. No splits though, and they are very comfortable.
No idea what the original seats came out of, but they have some of the beefiest brackets I've ever seen. You could probably lift the truck with them :D
In case anyone's thinking of trying it, bump seat runners are a pain in the butt to adapt to a La-z-boy - and you can't recline them in a standard cab unfortunately. I wasn't too happy with the color either, and my local Autozone apparently doesn't carry seat covers that fit. :lol:
MadJoe
Postby MadJoe » Tue Mar 21, 2017 3:12 pm
This weekend: I replaced the spark plugs, plug wires, changed the oil and oil filter, replaced the air filter, replaced the wiper blades and all 3 belts, plus adjusted the choke (multiple times, but if my ride to work this morning is any indication, I've finally done a pretty good job of that, even if I do say so myself).
What I discovered this weekend, as I replaced the plugs, is that carbon buildup in the cylinders is really bad. I could use some suggestions for cleaning that out; I've tried doing a Seafoam 'hot soak', but it doesn't really seem to have helped (although pouring a little in the crankcase did). Any suggestions? Just load the fuel up with cleaner? Maybe some MMO?
ETA: And my fuel filter and fuel hose was just delivered according to my Amazon app. So those will be replaced tonight or tomorrow.
Thanks,
-Joe
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
Ohiotinkerer
Postby Ohiotinkerer » Thu Mar 30, 2017 7:08 pm
Finished putting the exhaust manifolds back on - no more leak........ :woohoo: Put gas in the saddle tanks for the first time since remounting them - no leaks in the tanks or all my new plumbing........ :woohoo:
Then went and bought a lottery ticket to hopefully continue my good luck and to help pay for 57 gallons of gas it took to fill all 3 tanks......... :cry:
1968 F100 Baseline 2wd - Rangoon Red - 360 2bbl - T18 - power steering and manual brakes
1997 Honda CBR 900RR
1977 MonArk 14 ft jon boat with a 1963 Johnson JW-18 3hp outboard
Ohiotinkerer
Postby Ohiotinkerer » Mon Apr 10, 2017 10:25 am
Figured out after having the truck quit running on me at 70 mph on a 4 lane highway - and running like s@@t when I did get it going again - that my gas cap wasn't venting and building up pressure......... :cuss: This was after I wasted a beautiful Sunday afternoon going thru the carb and electrical system thinking I had a heat problem..........which I did - just in the wrong place....... :roll:
WarEagle
Postby WarEagle » Mon May 08, 2017 10:37 pm
This past weekend I put in a new sound deadener, heat shield and new carpet. Also recovered the bench seat in a nice dark blue. First time I tried it and I like how it came out!
1972 F100 300 cid straight 6
2009 F150 4.6L Super Crew
tsherry
Postby tsherry » Mon May 08, 2017 11:49 pm
Fine tuned the new Edelbrock 4bbl on the F-250, and finished the new-to-me upholstery on the F-500. Soon, diamond plate on the F-500's bed....
or, money.
Jacksdad
Postby Jacksdad » Tue Jun 13, 2017 9:37 pm
Finally got around to repairing the windshield wiper mechanism someone was good enough to vandalize.
Easy enough to get the dash out, but that's where the easy ended. Suffice to say, even after I heal, I hope to never have to do that again. So many sharp edges and teeny tiny spaces. And the steering column and wheel...:x
Nice to have a windshield wiper on my side again though :D
Jacksdad
Postby Jacksdad » Tue Jun 27, 2017 9:37 am
I got tired of leaning forward when I move the beast, so I put the bump seat runners on my '89 bench seat. Such a difference and one of the easiest jobs I've done on this thing - 30 minutes and it was back in and sitting at the correct angle. Not sure why I was putting it off :dk:
Lone Ranger
Postby Lone Ranger » Tue Jun 27, 2017 11:02 am
Jacksdad wrote:I got tired of leaning forward when I move the beast, so I put the bump seat runners on my '89 bench seat. Such a difference and one of the easiest jobs I've done on this thing - 30 minutes and it was back in and sitting at the correct angle. Not sure why I was putting it off :dk:
I just put a bunch of washers under my seats to get the angle I wanted :D
viewtopic.php?f=22&t=85251
Kyle
Jacksdad
Postby Jacksdad » Tue Jun 27, 2017 11:18 am
Hey, whatever works, right?
The thing is, I had the bump seat runners set aside waiting for the right bench seat and just got lazy. Mine was still sitting on the ones that came with the later bench seat and it was tipped forward a little too much. I literally dropped it in the cab so I could move it, and used it like that for a few months. I don't drive it other than to move it, so not being properly mounted wasn't an issue, but it's much more comfortable now it's at the right angle. Plus now I can think about bolting it in because the later runners didn't come close to matching the contour of the floor.
Postby Ranchero50 » Tue Jun 27, 2017 7:27 pm
10,540 lbs with me and the dog aboard. 2.03 tons of stone dust to help redo the walkway to the garage and settle some crush and run where I built a fence. Funny that when the mud flaps are 1.5" from the road, I'm loaded. Truck didn't seem to mind the load nearly as much as I do unloading it.
Builder of dreams, breaker of hearts. Play nice or go away.
71Fe2O3
Postby 71Fe2O3 » Thu Jun 29, 2017 1:38 pm
A few days ago I rewired the headlight circuits to include relays. I finally grew tired of living in denial, thinking that my eyes were worse than they are, or that the bulbs themselves had gone bad.
Relays, fusible links and ceramic sockets came from eBay sellers; fuses, wire and connectors from my father's garage. Dad, who died last year, was a mechanic, and because he taught me to appreciate old vehicles, it felt good to incorporate him into the old truck. I thought about him often as I used supplies and tools that were once his.
To minimize cuts in the stock wiring, I ran the new wires in parallel with the old ones. The only cut in the stock wire was near the high-beam switch, with new wiring from there to the relays, and also from the relays to the bulbs. The stock wire is still there in case I or future owners want to bring it back to Henry's original standards. To make it as neat and "professional" in appearance as my skills allow, I ran the wires through the firewall grommets alongside the existing wires-this was a bit of a bother, but I think it looks good, and, most critically, it works well.
Hours spent poring over the wiring diagrams from this site, learning about relays, and working out the plan on paper paid off in the end. Now that it is done I'm quite proud of it. As so often happens, it grew into a larger project than I had originally anticipated.
As I dug into it I removed the passenger's side vent to gain access to the firewall grommet. What a mess that was because the plenum was filled with damp and smelly mouse nesting material-that must be where the stuffing from the original seat went. That encouraged me to clean out the driver's side vent, which was equally disgusting and required removal of the emergency brake pedal, and also replacement of the slider, which came from my parts truck.
Running the wires from one side to the other inside the cab and getting them properly secured required removal of the instrument cluster, giving me the opportunity to replace the bulbs and clean the plastic "window" and also created a new headache when the speedometer cable wouldn't fit back in to the speedometer. It turned out that a strand of the cable stuck out enough to hang it up. After much head scratching, a bit of work with the Dremel took care of that problem.
Now that the job is done the headlights are remarkably bright, the instrument cluster is nice and clean (if only the gauges worked, but that's another project), and cool air, no longer filtered through mouse nests, flows through the footwell vents, offsetting the heat from the engine.
Fred
Jacksdad
Postby Jacksdad » Thu Jun 29, 2017 4:40 pm
71Fe2O3 wrote: ...and cool air, no longer filtered through mouse nests, flows through the footwell vents, offsetting the heat from the engine.
:lol: :lol:
Ohiotinkerer
Postby Ohiotinkerer » Fri Jun 30, 2017 12:56 am
:yt:
At least you didn't get a mouse turd shower out of the defroster vents like I did after my car sat for a year while I was stationed in Germany...... 55 MPH down the interstate in a rainstorm....flipped the defroster on and almost wrecked......... I would have been happier with just the smell.......... :(
71Fe2O3
Postby 71Fe2O3 » Fri Jun 30, 2017 7:19 am
A mouse turd shower-that sounds delightful. I am thankful to have learned about that from you rather than from direct experience.
I was thinking last night, perhaps the company that makes those fragrant tree-shaped scent diffusers should make one with mouse scent for the benefit of people who don't normally drive mouse-infested cars. No charge for the idea.
Fred
Return to “General Discussion”
Who is online
