What did you do to YOUR bump today?
No tech discussion, please
rwilly
Re: What did you do to YOUR bump today?
Post by rwilly »
Put on a canopy that I got from Craigslist. Its in good shape, doesn't appear to leak too badly. I think the gold stripes would look good painted to match my truck.
SeapineF37
Post by SeapineF37 »
ok68crewcab wrote:With the leaves falling I cut up a magnetic door sign to make some vent covers. Just lay them over the cowl vents and the leaves won't be coming into the cab. Since they are magnetic they stay in place even on windy days. Easy to remove when I'm ready to go for a drive.
:clap: great idea. going to have to borrow that one!
SeapineF37
rwilly wrote:Put on a canopy that I got from Craigslist. Its in good shape, doesn't appear to leak too badly. I think the gold stripes would look good painted to match my truck.
great find!
68FORDJBM
Post by 68FORDJBM »
Wow! That was a mouthful. I just washed mine:) You did remind me that I have a washer pump I need to install. Also, an new temperature sender and temp gauge.
fonfixer
Post by fonfixer »
Ok it only took 9 months of getting around to it, but I finally got the AM radio from my truck figured out. The truck sat for about ten years and in those ten years the radio just died. I found the schematics online, had to repair a signal generator (1950's era with vacuum tubes) and remember how to work an oscilloscope. After chasing voltage through the radio ruling out the likely components, I had to rethink my process. I started from the speak working backwards. I found one transistor that had shorted out causing high current draw of 2 amps. Now I need a 50 year old transistor or equivalent and this radio should come back to life! Down side of things, today is Thanksgiving and everything will be closed. Guess I should mention that I did radio repair in the military for eight years on Vietnam era equipment. These radios aren't to far away from them in design and operation.
1967 F100 swb 240 single barrel, manuel choke, three on the tree, style side
1967 F100 swb 240 single barrel, manuel choke, three on the tree, flare side
2011 F150 Crewcab Lariet w/Ecoboost (runs like a scalded dog!)
2019 Transit
My427stang
Post by My427stang »
1000 cfm HP series Holley to replace the 850 double pumper which replaced the 750 vac sec :)
Why? Had all three, wanted to compare and dial them in to sell. Going to go EFI soon. All the carbs ran great, but it really liked the 850 for raw power and the 1000 HP vac sec is so close but a little more finesse without the second accel pump (really an 850 vac sec with no choke, Holley just rates it a 1000)
Today going to run the valves, it's a solid lifter build, and get some miles on it this afternoon. Next is swap the Duraspark box for an MSD with a rev limiter, then try to get the 4x4 suspension to squat and hook a little
cj 69f250
Post by cj 69f250 »
installed my new used tailgate. The one without all the rust holes...Even color matched it pretty well ;)
grnf100
Post by grnf100 »
The past week and a half. Got ol' girl running again. (after 2 years sitting) Had a broken wire coming into the starter solenoid preventing startup. Added some gas and she purrs once again. Cleaned her up. Wash & wax. Cleaned out the bucket worth of leaves in the cowl. Pulled off some old rusted bed rails. Cleaned up the looks a lot.
Noticed carb is leaking at the front. It is truly amazing how well this truck starts up to be 47 years old. (1970 F100 Longbed) Bump the key, and engine don't even get to turn over before she starts right up!! Next.... Carb rebuild!!
Ohiotinkerer
Post by Ohiotinkerer »
Since we had a rare sunny 48 degree day here in miserable Ohio I decided to start the old girl up and let it warm up since it hasn't been started for 2 months - readjusted the choke idle speed and hit the saddle tank bolts with some blaster so I can hopefully get them out and replace them with new ones - took some mesurements so I could make a new top plate for my fuel tank switch at work - and last but not least propped up the old school grille guard that I found after 5 months of searching to see how it looked!
1997 Honda CBR 900RR
Put a fuel pin and another 366 spring in my pump yesterday. Launched the top hat and spring into the gravel during a mistake and took a couple hours to find all the pieces and get it back together. Took it for a ride and it's still topping out around 2300 rpm. I also tweaked the pressure switches for my trans lock and now it's dropping out of OD when I let off the throttle. Should have just stayed in bed.
grnf100
Post by grnf100 »
Carb is off! GETTING REBUILT! :D
Ohiotinkerer
Discovered after the downpour we had last night I STILL have a leak on the drivers side somewhere...... :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss:
HIO Silver
Post by HIO Silver »
Warmed it up, took it for short drive, and put about seven gallons of gas in it. The gas gauge is on the fritz again. After all that gas, it barely indicated a quarter tank. Frustrating.... gonna have to install that 72-80 Scout tank sooner than later.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
Rocket Doctor
Post by Rocket Doctor »
Waded through the hip-high snow to look longingly at my recently inherited 67 F100 4X4 that Dad bought new.
Jacksdad
Post by Jacksdad »
Rocket Doctor wrote:Waded through the hip-high snow to look longingly at my recently inherited 67 F100 4X4 that Dad bought new.
:thup:
I pulled the front wheel and drove to the gas station to re-inflate the tire after finding it dead flat. Funny thing - the cap was missing from the valve stem and it seems to be holding air just fine at the moment... :x
