STICKY: Best mods or upgrades you have done to your bump?
No tech discussion, please
390F100
Re: STICKY: Best mods or upgrades you have done to your bump?
Post by 390F100 »
:yt: Show off :lol:
Mine is not complete and I have never driven her in the year and a half I have owned her so I would say from my previos experience with my old bump, getting the Pertronix installed has to be one of the nicer ammenaties for my old girl...I remember with my old bump and the points driving down the road at night and having 4ft long flames shooting out the exhaust, although very loud and awesome cause it lit up the street, Idont want that to happen again. :oops:
390
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
BradyCouchman
Post by BradyCouchman »
ok this is going to sound bad but the best thing i did was put a mopar ignition system in her...used a duraspark 2 dizy with the mopar box.
or replacing the worn out busted 460 with a new long block.
1970 Crew Cab 460CI 2WD
06 Focus Daily Driver
ArizonaDan
Post by ArizonaDan »
Do tools count?
If they do then my answer is a Lincoln Weld Pak 125 HD. Sweet Mother Mary and Joseph I'm having fun with this thing! I had never welded anything before i bought this for the sole purpose of resto-modding my '68 F100. I have to tell 'ya wire feed welding is nothing to be intimidated by. The most critical factor with these types of welders is to get the metals to be welded as clean as possible. It makes all the difference in the world. Great fun! And you discover a whole new level of creativity when you work with metals.
I have cut out and replaced patches in the floor, cut out and replaced a section of the "bump" that was crunched on the bed, patched the hole where the under-bed fuel tank filler used to be, patched the hole in the cab where the fuel selector valve used to be, all within the first week of owning this machine. I'm no expert welder but I now have complete confidence that I can do metal fabrication work to a high degree of quality workmanship. I now look at scrap metal piles in a whole new light just imagining what I could do with a grinder, a cut-off wheel and my trusty little Lincoln. Quite possibly the best $450.00 I have ever spent.
Dan
1968 F100 -360, 2BBL, C6, 3.25, ugly? yeah, she's ugly.
1997 Expedition -4.6L, 4WD, 14MPG, gutless? yeah, she's gutless.
2001 Kawasaki ZRX1200R, fast? yeah, she's fast.
tybob81
Post by tybob81 »
I think the two best upgrades on my 68 have been the ididit tilt wheel and power steering. Well maybe three the dealer a/c I rebuilt and installed.
71 LONG BED
Post by 71 LONG BED »
As simple as it sounds, I'd say the intermitent wipers. It took less than 15 minutes to put in and it works great! Seriously, you could install it on your lunch break and still have to eat your sandwich.
John Member #1549
Image Image Image
austin
Post by austin »
mine has to be installing a cd player with four speakers and my engine upgrades bigger cam .30 overbore headders and dual exhaust on an inline six
HillbillyDelux
Post by HillbillyDelux »
so far crane cams electronic ignition and the electric fan
im sure when i get my intermittent wiper switch itll be near the top of the list too
2000 Ford Ranger 4x4 "DD"
2003 Cobra
"If it ain't broke fix it til it is"
Alvin in AZ
Post by Alvin in AZ »
Wow, this thread is moving kinda slow so...
http://www.panix.com/~alvinj/file12/toe-in1.jpg
http://www.panix.com/~alvinj/file12/toe-in2.jpg
The few times an "ex-spurt" adjusted my toe-in, it was too much "in", like an 1/8" or more. :/
I even experimented with a little toe-out and decided that 0 to 1/32" in was my favorite. :)
Stopped the bad tire cupping problem I had since the pickup was -new-! :)
I believe my method with the cement blocks to be better than using a helper because the
cement block is consistent and not got anything better to do so is thinking only about holding
the 1+1/2" thin-wall square-tubing and nothing else. ;)
Two tricks to it, one is to use a 1" wide tape measure or bigger and learn how to repeat your
measurements. Second is to figure out what angle your steering wheel sits while going straight
down the road and have it at that angle when measuring the toe. That angle will change with
a change in the toe adjustment.
Has worked out really good for me. :)
IME, it's better than "pro" work, YMMV.
Something that might be very important here is how my rear axle is -square- with its frame.
Also the position and "squareness" of my front eye-beams are right on the money too. :)
And the front end's "right height" as Ford calls it is good on mine too...
http://www.panix.com/~alvinj/file12/rideheight.jpg
Measure yours and correct those problem first, IMO.
Alvin in AZ
Alvin in AZ
I added a Dana speed control system to my '75 F150 in '77. :)
It was on sale at Sears for $79, got it through the catalog. LOL :)
http://www.panix.com/~alvinj/file12/speedcontrol1.jpg
http://www.panix.com/~alvinj/file12/speedcontrol.jpg
{edit} http://www.panix.com/~alvinj/file12/throttle.jpg
Only problems I ever had with it were caused by the 3M
wire connectors! What a pain in the ass those things are! :/
Later I used simple butt connectors and shortened all the
wires and it's worked perfect ever since. :)
Also lost one magnet off the driveshaft and it quit working,
so I readjusted it to work with one magnet and found out it
worked better than ever after that. Later found out the old
instructions were wrong to have me put two magnets on it
to start with. :)
Alvin in AZ
sport71
YUP!!! Best mods or upgrades you have done to your bump?
Post by sport71 »
Crapet and tilt :D
Rear disk :thup:
Sound deadener :zz:
Working scoop :woohoo:
Rear tank :hd:
Hanger flip :wink:
Filled in the light, and left some slits :maybe:
New A/C :yip:
Those who do not learn the lessons of history, are doomed to repeat it.
Fordtastic
Post by Fordtastic »
71 LONG BED wrote:As simple as it sounds, I'd say the intermitent wipers. It took less than 15 minutes to put in and it works great! Seriously, you could install it on your lunch break and still have to eat your sandwich.
where did you get them?
'72 F100 302 4sp manual
1971ford
Post by 1971ford »
Full rollcage, 5 point harnesses.
Nothing like having no fear in rolling :thup:
and the 429 of course.
-Ryan
ak-1970-360
Post by ak-1970-360 »
I would have to say my best mod is the homemade 4'' lift and 35/12.5r15 mickey thompson baja claws. Its also the most fun when out in the nasty Alaska mud and crud. Hopefully soon will be the new 390 so i have some power to turn those tires in the muck, my 360 is pretty much toast.
Josh
1970 F100 4x4, 360 FE, NP435, 9", factory 4.10, Homemade 4" lift, 35/12.5R15 MT Baja Claws- ultra budget 4x4 toy
2001 F250 4x4, Powerstroke diesel, auto, 140hp TS Performance chip, AFE cold air intake, hopefully adding soon- Jobe performance cold air intake, CFM+ intake manifold, 4" turbo back custom duals, stage 2 injectors- Daily Driver
Hot Rods have a Ford in front and a toolbox in the back, street rods have a chevy in front and a can of wax in the back- Mr. Offenhouser
07 Harley Davidson Nightster, 1200 with stage 1 programming, RSD intake, straight pipes, and Ape Hangers!
eggman918
Post by eggman918 »
twin stick TC shifter.stock drum brakes suck in mountains, 2-low is handy
Steve
sport71
Post by sport71 »
I just put Pioneer DVD flip out 7" screen, 2 amps, with 2 - 12" woofers where the gas tank used to be, and 4 - 6x9's. The best sounding $1800 I've ever spent.. :D It took me like 3 years to get it though.
Here are some pics..
if you look in you realy can't tell it has a system. (I'll be hiding the yellow wire ).
The speakers are down to 1 ohm.
:D :D
