New addition to the family 1967 F100
I have a relatively early 67 according to the VIN. Looks like October 66 built in Norfolk. Its a 352 3 speed on the column, no PS or PB. I was reading the technical articles on the special one year only 67 quirks and noticed no mention of a truck with a dash and heater controls like mine. Anyone else have a dash like this? Also the tag says my hp is 172 at 4000 rpm whereas the article says 204. Just wondering if this earlier truck is different from the later ones in 67.
2012 Chevrolet Silverado 2wd 4.8 ls auto
2002 Toyota Sequoia 2wd 4.7 auto
1985 GMC 3/4 ton 2wd 350 automatic
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1971 F100 2WD LWB 302 T18 3.70 9inch PS PB
1970 VW Type III squareback cut into pickup dual carbs
1967 Ford F100 LWB 352 3.03 9inch
1967 International Travellall Panel truck
1966 International Scout 800 4X4
1964 Chevrolet C10 on 1986 4X4 frame 350 700r4
1958 Chevrolet DelRay 235 3 speed
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
- 69Ford
Re: New addition to the family 1967 F100
I believe there are posts somewhere on this site about this. If I remember right its very rare to not have the push pull heater control knobs under the radio. Do the research and let us know.
I've heard that back in the day heaters were an option in warm climates , maybe it was dealer installed later ?
- Ranchero50
I think they were the very basic model heater. The deluxe ones had cable remotes.
The farthest left know is the push pull turn type know we are accustomed to. It works perfect. For defrost you just have to reach down and turn the bent rod sticking out of the heater box under the dash. If you look close you can see it.
- jzjames
"economy" heater controls as opposed to "deluxe". Nice!
- Ranchero50
Yep. I'd prefer to have one of those vs. the late model super deluxe binding cable version. I finally gave up and chucked the defrost cable and set the lever mid way. My water valve leaks by so it's either hot or really hot in the cab with the windows up.
- TexasVine
1967 Ford 100/352/4 speed/PB/LWB
2014 Ford F150 KingRanch 4x4
