Need input on two post lifts
eggman918
Post by eggman918 »
We have finally got to the point that we can build my shop and I am planning to get a two post lift at the same time.
I need input on models and brands as I have no experience with them, I need basically a "truck lift" as my truck is at or over 8,000# and fairly wide/tall.
My plan is for a 30x40 building with 12" eaves a walk in door and a roll up bay door, i want room for my machine tools, the lift, space for a project or two and storage and I'm sure the wife would like to park her car as well, so I might also have a 20x30 covered slab poured in front at the same time.
So who has a lift what brand and model and how has it treated you so far???
Thanks in advance
Steve
tsherry
Re: Need input on two post lifts
Post by tsherry »
I built a 40W x 30D shop last year--12' ceilings, two 10'-6" doors and one man door. All three doors are on the 40' side, with the snow / rain draining off to the sides, rather than the front--you don't want ice and rain landing in front of your doors.
if you're planning on a lift, plan on thickening the concrete slab under where the posts will go to handle the mounting bolts, and it wouldn't hurt to prepare for things like a slab-mounted vice stand and ditto for a grinder stand.
I don't have a 2 post lift, but did manage to score a low rise lift for tire and oil changes and brakes and stuff with a 6500 lb capacity for....$400. Thank you, Craigslist. Mine is made by Rotary.
I'd get schooled on various brands, and then see what CL has available--there are usually two or three two- or four-post lifts available every month or so.
or, money.
eggman918
Post by eggman918 »
Doors and covered slab are going on the end with the peaks and it will be facing south so it will have sun in winter and shade in summer :thup:
Steve
jamesdfo
Post by jamesdfo »
One thing to watch is what the power requirements are for the hydraulic power pak on the lift vs what power you have in your shop (110, 220, 3 phase). I know of a couple people that bought a used lift, only to find out the power pak was not compatible with their power. And replacing the electric motor on the power pak to work with their power takes a lot of the deal out of a CL deal......
James
