Torquing Ring Gear Bolts: One way to do it when you're alone
Madman
Postby Madman » Fri Jun 27, 2014 9:31 pm
I though some of these tips may come in handy if you find yourself working alone, like I do most of the time! :D
2017 Ford Raptor
1975 Ford Bronco
Madman
Re: Torquing Ring Gear Bolts: One way to do it when you're alone
Postby Madman » Fri Jun 27, 2014 9:32 pm
The board supports the differential, the pinion, and the wrench....the wrench bites into the board as does the pinion, it works damn good!
2017 Ford Raptor
1975 Ford Bronco
crazyhorse
Postby crazyhorse » Fri Jun 27, 2014 11:48 pm
Mr Madman , that is very good tip/idea.
Thank you for taking your time to share this .
Madman
Postby Madman » Sat Jun 28, 2014 12:31 am
And thanks for appreciating it! :D
2017 Ford Raptor
1975 Ford Bronco
Mancar1
Postby Mancar1 » Sun Jun 29, 2014 6:52 pm
:thup: 8)
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
trozei
Postby trozei » Wed Nov 19, 2014 3:51 am
Another good idea!
Return to “Garage/Workshop & Tools”
Who is online
