Valve cover gasket tip...
Re: Valve cover gasket tip...
Postby rollercam1 » Tue Jan 19, 2016 12:47 pm
Because cork gaskets suck.
Postby 1972hiboy » Tue Jan 19, 2016 2:43 pm
I put cork gaskets on dry now. the idea being that oil would soak into them and cause them to swell making a better seal. I always used to put sealer on them and they did end up leaking quite badly. The last 390 I did my machinist told me to put it on dry so I did. They have held up very well. :2cents:
1972 f250 ranger XLT Camper Special 390
Dont eat yellow snow.....
Postby dailyf100 » Sat Mar 12, 2016 8:22 am
Here is a tip. Throw the cork gaskets in the trash! Spend a few extra buks on some steel reinforced rubber gaskets and save yourself some time and hassle as well. They are also reusable. Best thing I did in a long while and they won't leak.
Postby 1guydude » Sat Mar 11, 2017 3:08 pm
I didnt use any. Also i wish i saw those clips earlier. I know i have some large ones sitting around. Dang. Good tip.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
Postby Ohiotinkerer » Sat Mar 11, 2017 8:14 pm
Something else I also do when changing oil pan or valve cover gaskets is lay the edge of them on a piece of metal and tap around the holes to make sure the area around them is flat. When I worked in a local garage you wouldn't believe how many I had to do that to because they were leaking and someone overtightened them thinking that would stop the leak and bent the edge of the holes down........
1968 F100 Baseline 2wd - Rangoon Red - 360 2bbl - T18 - power steering and manual brakes
1997 Honda CBR 900RR
1977 MonArk 14 ft jon boat with a 1963 Johnson JW-18 3hp outboard
the elder rocker
Postby the elder rocker » Sat Oct 07, 2017 9:28 am
Same idea, different approach---- I've always kept a pack of clothespins around the shop. Versatile, low clamp pressure, handy and ............Dirt cheap! I just keep them clipped to the card they came on hung on the pegboard.
Your humble Rural Engineer-
Mike Burgess
Albert, KS
HIO Silver
Postby HIO Silver » Sat Oct 07, 2017 8:28 pm
The problem with cork valve cover gaskets is the person installing them.
It's a matter of bad technique and poor attention to detail than the material itself.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
Return to “Garage/Workshop & Tools”
Who is online
