Need some advice about hauling my frame.
JWW
Post by JWW »
I figure I can count my trailer as a tool, so I will post my question here.
My trailer is a 5x8. My F100 frame measures close to 16' long. Am I asking for trouble trying to haul my frame with this trailer? I'm not concerned about the weight, however the length does concern me.
Has anyone here used such a trailer to haul their frame on?
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
Re: Need some advice about hauling my frame.
is it a rolling frame? if not forget it. or put the front axle up on the trailer and strap that down to the trailer. or get a longer trailer.
JWW
Post by JWW »
No, it is not a rolling frame. I have removed everything from the frame.
JWW
2004 F150 Crew Cab
you will have a imbalance of the frame on the trailer. it wont be safe to do it with a imbalance i dont think. maybe someone can figure out away to do it. you can only hang it over the hitch end so far before it goes into the turning radius of the truck and trailer. it might work i dont know.
71PA_Highboy
Post by 71PA_Highboy »
It can be done.
What you need to do is secure the frame on the trailer so that the frame horns clear the towing vehicle when turning.
Next, secure it some more.
Put red marker flags on the end of the frame extending the trailer to warn anyone following you. Magnetic lights are better, but $.
Finally, put sand bags on the front of the frame, within the boundaries of the trailer, and secure them to the frame (Duct tape works). This is to ensure proper tongue weight on the trailer and to make sure the 'hanging' end of the frame does not bounce too much.
Secure the fame some more (get the picture?)
This will allow you to move the frame safely for short distances.
If you are talking long distance, then I would rent a trailer.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
JWW
Post by JWW »
Thanks for all the quick replies. I may just rent a trailer to be safe instead of taking the chance. I'll keep you posted.
JWW
2004 F150 Crew Cab
Caseys71
Post by Caseys71 »
71PA_Highboy wrote:It can be done.
That's a good idea! 8) I wouldn't have thought of sand bags up on the front the trailer, and yet it is probably the best solution for giving the trailer some tongue weight even with the frame hanging over the back of the trailer more so than over the tongue.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
Heathcliff68f100
Post by Heathcliff68f100 »
Sounds like a good idea, but you might need so manny sandbags you overload the trailer or the tow vehicle. id rent a trailer, or if you have a ladder rack for a pickup get it on the ladder rack and strap it down
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
JWW
Post by JWW »
Well guys, I figured out a way to haul my trailer...
Get a buddy whose trailer is bigger. :lol: Luckily a good friend of mine helped me load it and take it to the sand blaster. Then, he helped me get it back to the house. Good friends are hard to come by.
Thanks for all the suggestions. :thup:
JWW
2004 F150 Crew Cab
