Gasoline/oxygen cutting torch
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
http://www.petrogen.com/welcome.html
found this over at Pirate's site. looks interesting, and at the mentioned E-Pay price of $550, it seems comparable and might pay for itself in savings on fuel.
binder56jd
re: Gasoline/oxygen cutting torch
Post by binder56jd »
wow- looks like a good set-up- thanks for the link 72 :thup: :thup:
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
mcarlson11
Post by mcarlson11 »
I would prefer to use Acetylene and oxygen rather then gasoline.
When the going gets tough, your doing something right.
binder56jd
yep- i'd like to hear from someone who has had the chance to cut with that setup before pronouncing a final sentence
now serving #235
spartman
Post by spartman »
So I shouldn't be using acetylene and oxygen in my cutting torch then?
At the last place I worked at I was told that the acetylene was a hotter gas and worked better than propane.
binder56jd
I found this explanatory page regarding propane cutting rig
http://members.aol.com/Idcamper/All-States.html
sounds pretty convincing- cost wise on gas - acy cut's ok- it is high and i guess you could use any lp bottle
i'm gonna look for more info on the gasoline rig - the main thing i see is the cost of a new cutting rig vrs. how much it's used
now serving #235
72hiboy4x4
propane has a cooler temp, but for the home fab'er, it should work fine. lots less soot, cleaner cuts, and being able to steal the B-B-Q's tank when your torch runs out during a late saturday fab session? priceless!
Heathcliff68f100
Re: Gasoline/oxygen cutting torch
Post by Heathcliff68f100 »
Actually, nothing is better than acetylene imho, its the hottest burning gas used in welding , provides better cuts on thicker plate, i mean sure it has its drawbacks, but, it also takes less time to preheat the metal to kendeling temperature to start the cut, if its worked so well for so long, why change now?
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
fireguywtc
Post by fireguywtc »
I have used oxy/gasoline before. It is used in rescue type enviornments because of its supply of fuel and it can cut through up to 13" thick steel. It is a lot more tempermental to work with the acetylene since it constantly needs primed and takes about a min. to get buring well. The flame starts to fizzle out after a couple of min. and you have to go prime the gas can up again.
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
Heathcliff68f100
thats the reason id rather use acetylene, NO PRIMING, just heat, and cut
i didnt read this post before. but i can tell you from experience that propane sucks for using as a cutting torch. i couldn't use it at all. my brother in law uses it. but i couldn't get his setup to work. it was taking too long to even heat up the metal before i could even think about doing a quick cut on something.
eggman918
Post by eggman918 »
Have used propane for a huge rosebud head ,worked well but from the size difference between propane to acetylene I think you would over sized cutting tip high fuel PSI to work.
Huge difference in energy content between the two I think :2cents:
No one mentioned if they are using a propane tip there is a difference in "jetting " in the two and usually a bigger regulator for propane
the one i used was made for acetylene. it wouldnt cut for s.
eggman918
Post by eggman918 »
try one that has been cleaned so much it is no good for acetylene :2cents:
that will be closer...but still a bit small :hmm:
its not my torch setup.
