1967 F100 Steering Wheel (Lunar Green)and horn Ring
Jaddiethelady
Postby Jaddiethelady » Mon Oct 09, 2017 2:47 pm
HI there! I know it is a long shot but I am looking for a 1967 F100 Lunar Green Steering wheel and the horn ring to go with it. It is the last thing I need to complete my truck! I have a fully functional steering wheel I can trade if you are interested, if not of course I have cash. I am specifically looking for a Lunar Green one which is a light teal color. The one I have is a dark turquoise if anyone is interested in it. Thanks in advance :)
colnago
Re: 1967 F100 Steering Wheel (Lunar Green)and horn Ring
Postby colnago » Thu Oct 12, 2017 12:55 pm
You might have to paint it. I also have a lunar green truck, and my steering wheel has a ton of cracks. it's also so worn that it's streaked half green and half black. I figure on patching the cracks during the winter months, then painting it when I paint the truck.
hdman90
Postby hdman90 » Fri Oct 13, 2017 7:40 am
Bondo seems to work well. Fill the cracks, sand them down, and paint.
I believe that your lunar green wheel would have simply been a painted item from the factory. They did not make the actual wheel out of that color material.
Ohiotinkerer
Postby Ohiotinkerer » Mon Oct 16, 2017 8:29 pm
hdman90 wrote:Bondo seems to work well. Fill the cracks, sand them down, and paint.
It helps if you chamfer the cracks a little then fill them - I use a Dremel with a small pointed deburr bit to widen them out a little on top - dad did this on his '59 Impala wheel 20 years ago and its still holding up..... :thup:
1968 F100 Baseline 2wd - Rangoon Red - 360 2bbl - T18 - power steering and manual brakes
1997 Honda CBR 900RR
1977 MonArk 14 ft jon boat with a 1963 Johnson JW-18 3hp outboard
Return to “Parts Wanted”
Who is online
