WTB: Front Driveshaft for Short-Tail C6
Postby colnago » Fri Sep 08, 2017 9:59 pm
I'm looking for a coupling shaft for my 2WD longbed. This is the shorter shaft that goes between the transmission and the carrier bearing. From the center of the U-joint to the front of the carrier bearing, it is 25-1/4". From the center of the U-joint to the end of the splined shaft, it is 32-1/2". My C6 has a flange bolted to the output shaft, not a slip-yoke.
Return to “Parts Wanted”
