radiator support bolts
i need the bolts and the bushings for a 1967 f250
Re: radiator support bolts
I need them too.
i just got some at the pull and save over here if i get a chance to find some more good ones i can get them for you do you just need the bolts or the bushings as well?
Just the bolts.
I need 1 bolt and 1 big cupped washer while your looking.
allright there putting about 6 more trucks in the yard by friday up at the north yard they just opend (nicest salvage yard i have ever seen) and i will go there friday and get the parts if there is anything els small you need let me know
(2)67 door jamb switch brackets
what brackets?
havent been able to get out there yet but just let me know what all you guys need and i will find them im going to see if a guy i got parts from still has his 67 parts truck
I need the brackets and wiring for the door jamb switches/dome light. Its the switch that has the button on it that turns on the dome light when you open the door.randymartinjr wrote:what brackets?
- BobbyFord
Doesn't Dennis Carpenter sell a radiator supprot bolt/bushing set?
