Closed Knuckle HD 44 (spicer hubs)
Private parties only. No eBay/Craigslist listings.
71mishmash
Post by 71mishmash »
Hi guys,
I thought I put this up just in case someone was looking for one that is 95% complete. I removed this axle and installed a 76 open knuckle under my truck and it is now taking up valuable rel-estate. I know a lot of you are converting to disc set ups but if this might help then let me know. Not sure of it's value but let me know and we'll work out something. It is complete with the exception on one hub. The newer axle needed a replacement. The king pins and seals on the knuckles will need some attention as the pins are not tight, and there is weeping from the knuckle seals. All to be expected from a used axle.
If it's something you can use lets chat. I'm not looking to get rich. It's a heavy sun of a gun so if you want to have it shipped that might be the more expensive aspect.
