1967-72 f100 parting out
Private parties only. No eBay/Craigslist listings.
71mishmash
Re: 1967-72 f100 parting out
Post by 71mishmash »
Hi,
Just wondering if you might have a fan shroud for a 71 super cool rad?
Thanks
Grandpas72
Post by Grandpas72 »
Interested in driver and passenger fenders .price on 1972.
colnago
Post by colnago »
I'm looking for a front driveshaft, approx. 33-1/2" from center of u-joint to the splined end.
59yblockf100
Post by 59yblockf100 »
dont have a front drive shaft,all are 2wd,will have to check on condition of front fenders,no shroud,
colnago
Post by colnago »
Not the shaft for a 4x4. I think they're called coupling shafts. It's the short shaft from the tranny output shaft/yoke to the carrier bearing. I'm changing trannies on my 2WD, so I need a new coupling shaft.
59yblockf100
busy right now now,next weekend i can see if i have the right size,i have a few,
rbmgf7
Post by rbmgf7 »
Looking for a spindle assembly. 2WD with drums. Would be nice if I could get at least the hub and drum backing plate.
pchelp101
Post by pchelp101 »
Sent you a PM
1969 F100, 390, 3 Speed, 2WD
urchinhead
Post by urchinhead »
I am looking for a good '70 grille shell and an original Carlite windshield; do you have any of these parts?
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
darren121671
Post by darren121671 »
Im looking for a heater control valve cable. Its app 36-3/4 long.
stonebystone
Post by stonebystone »
If you're still selling parts, I'm looking for the power steering column bracket that bolts to the outside firewall. I'm converting my '67 to Saginaw power steering. Thanks!
59yblockf100
i only have manual steering brackets
ian1967
Post by ian1967 »
I was wondering if you had some parts available, 1967 F100
Grill, grill upper panel, front bumper, radiator support, driver side fender, and hood latch rod.
thanks
ian1967
Post by ian1967 »
wondering if you have driver side fender and lower fender cap, radiator support, driver light bezel? thanks
elvis67
Post by elvis67 »
hi Im looking for small block perch part betwen crossmenber and engine support 302 351 winsor thank you
