new member from pa
new member from pa
hi guys..i have been lurking for awhile now trying to gather info on these older fords and fe motors...i recently was gifted a 69 ranger 250 from my uncle..finally got it towed to my place this weekend..
truck does have original 390 and c6 inside. i would really like to swap to a modern 5 speed manual as the resto goes, like a tko or the like. we recently parted his 70 250 that was a 390 with a four speed, so i saved alot of parts from that..
truck is fairly original, and hasnt moved since late 80s. has the classic corner roof rot but is fairly solid, especially underneath..i gave it a good bath once home.
uncle has some nos parts for it....front grille and buckets, upper and lower body trim, various interior parts..truck does have original 390 and c6 inside. i would really like to swap to a modern 5 speed manual as the resto goes, like a tko or the like. we recently parted his 70 250 that was a 390 with a four speed, so i saved alot of parts from that..
69 f250 ranger 390 auto 2wd
96 f150 eb 4.9 m5od 2wd
08 fusion sel 2.3 mtx
Re: new member from pa
from Massachusetts.
- magic bus
Nice truck and grille. Your fortunate to have all those parts!
70 Mustang Coupe 302 C4
97 Expedition 4x4 Eddie Bauer
- 67mann
from NY nice truck
- Manny
Clean good start for a truck. She will treat you right. Disk brake truck??? Like it lots welcome to the best forum ever.
yeah power disc, power steering..this site is definitely pretty awesome! im pretty solid on the 80-96 body style..as i have 7 years experience ford tech experience in addition to owning several fords..but these old girls are a little different. winters here but i hope i can post up some more pics with time.
Mr Justin to the best site period.
Hope you like it here.
Pull up a chair and stay awhile.
Good looking truck.
Good looking truck.
- hdman90
Justin,
from Erie Pennsylvania! Where abouts in PA are you located??
Very nice start! Keep us posted!
thanks for the welcome guys...im located in mercer pa.
im hoping the motor isnt seized...had a hard time getting the plugs out, then i sprayed a large amount of sea foam "deep creep" in each plug hole to let it sit for awhile. many things under the truck are pretty nice/solid, including the cab mounts..water dripping on the truck and getting on and in the engine bay was bad..
- cstoyer
Welcome from Michigan! Great looking truck can't wait to see more!
Kyle
Kyle
- Manny
justintendo wrote:thanks for the welcome guys...im located in mercer pa.
Just remembered i knew this trucks twin...
- hdman90
Which also looks very much like this truck!Manny wrote:justintendo wrote:thanks for the welcome guys...im located in mercer pa.
- Manny
Them lights are hideous!!!!
- hdman90
they are, but they're era correct! and you don't see them often anymore... I may just keep them!Manny wrote:Them lights are hideous!!!!
