I just found this site while on a search for wire harness info. I have a '61 long box Merc Uni , this has been "in the family" since 1987. I recently found I was without brake lights when applying the pedal, the interior light came on instead! Signals, 4 way flashers do work.
I found the feed and return to the brake switch overheated and the magic smoke had leaked out of the harness!!
The online schematics have saved me several hours of flustration at least a colour code helps translate the rest of the damage!
Tracking these wires thru the debris and now under the dash it appears that Ford in their infinite wisdom have fused what appears to be an 18 gauge stranded wire with a 15 amp fuse.
Thnx B
Brian in Kinmount Ont Canada
61 Merc Uni
61 Merc Econ Pup
76 T ' bird
Magic Smoke Leaks!
- 67mann
Re: Magic Smoke Leaks!
from NY.... I think there is a board for the "slick's" you have Slick 60"s
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Welcome aboard from Northern Ca.
Yes there is a site called Slick 60's, but I am sure you can get good info here also.
You may want to post your questions in the electrical section.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- MadJoe
from MA!
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
