Hello, my name is Jim and new to the forum since January. Over the last couple years I have read lots of info from this forum and another. I have a 1970 f250 sc cs. I have had the truck about 20 years but it had been parked until last year when I finally put it on the road. This hasn't been a restoration, I've just been replacing and rebuilding parts.
Replaced the ruined original 360 with Short block 390 standard bore, machined the heads. That was 20 years ago then it sat. About 5 years ago I put in new auxiliary tank, sending unit, and filler neck hose. Year and a half ago I switched to aluminum intake and 4bbl holley. Registered it for the first time a year ago and since then fixing a little at a time.
Over the past year i have replaced MC, vacuum lines, front calipers, radius arm bushings, shocks, dimmer switch, door weather stripping, brake booster, power steering hoses, and tires. I don't think I have forgotten anything. I still have a few parts to replace before getting another batch. Post a pics next.
New member
- ok68crewcab
Re: New member
thank you and welcome to you as well. This pic is from a year ago but the truck still looks the same minus the camper hardware on the bed.
- 1970FordTK
Re: New member
Welcome from North Carolina.
Re: New member
from Massachusetts.
- 67mann
Re: New member
from NY looks solid
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Re: New member
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: New member
Mr Jim to the best site period.
Hope you like it here.
Pull up a chair and stay awhile.
Re: New member
from Michigan. Nice looking truck you got there.
Kyle
Kyle
